TwinTurbo.NET: Nissan 300ZX forum - If you can replace the center bearing cheaper than buying
zellamay
on April 08, 2011 at 2:27 AM
OEM driveshaft - repair or replace with 1-piece?
posted by EUGENE
on April 07, 2011 at 11:46 PM
a one-piece driveshaft, then it's a no brainer. The best any one-piece can be is "as good as" stock, and sometimes, (as Draker said you should search this topic), it's much worse.
EUGENE
23:46:31 04/07/11
It's up to you really..
Draker (Eugene, OR)
00:23:36 04/08/11
If you can replace the center bearing cheaper than buying -
zellamay
02:27:43 04/08/11
You can do either...
Drunkpunk082
11:41:09 04/08/11
If you go with replacing the center bearing on the OEM>>
ZUL8TR
15:22:14 04/08/11
PS Here are Courtesy Nissan prices on the OEM 2 piece>>
ZUL8TR
15:28:46 04/08/11
